Cam Cap required!
JOHNO23
Cam Cap required!
#1 PostAuthor: JOHNO23 » Wed Jul 04, 2012 10:48 am
Hi Guys , anyone got a cam cap. Do I need the same one as the one that is buggered.
steve bowdler
#2 PostAuthor: steve bowdler » Wed Jul 04, 2012 10:51 am
I think you are going to have to buy a few to try to match to your cam unless you are very lucky as these are machined for your cams , some may be too tight ! Think this is correct :cry:
http://www.z1ownersclub.co.uk/forum/vie ... ht=cam+cap
#3 PostAuthor: z1bman » Wed Jul 04, 2012 10:59 am
£30 from john browse in wrexham
JOHNO23
#4 PostAuthor: JOHNO23 » Wed Jul 04, 2012 11:20 am
SORTED Cheers..................................good here innit!
#5 PostAuthor: z1bman » Wed Jul 04, 2012 11:25 am
make sure you Haven't damaged the tacho gear on the cam as this is normally the cause for for a broken cam cap on that side of the engine?
#6 PostAuthor: zed1015 » Wed Jul 04, 2012 11:37 am
You don't need another cap (see my reply in your original post)
Remove the broken bridge and use as two seperate caps (ala z650 etc).
Mark their original locations so they don't get mixed up.
Ideally fit a second dowel to each cap but not crucial.
They were only made in pairs for manufacturing simplicity.
Users browsing this forum: No registered users and 4 guests
