New to the site.................Already have a problem
JOHNO23
#1 PostAuthor: JOHNO23 » Sun Jul 01, 2012 5:38 pm
Hi Guys, I'm new to the site, so hello all.
Have recently picked up a Z1000A1 (will post pics when worked out how to)
The bikes in reasonable condition, requiring a little TLC, including paint job, bit of re chroming etc all the usual stuff.Engine sounded pretty smooth although has a couple of leaks mainly from the rocker cover and the cam chain adjuster. Nothing that can't be put right fairly easily..........................However! On getting the bike home, I discovered that some cock has done a piss poor job of helicoiling a fucked plug thread. The owner forgot to mention this.The worry is now, the helicoil has gone and the plug fits in the hole like a dick in a shirt sleeve, can it be repaired in a better more permanent way than a helicoil. Any one have any ideas? The other slight problem is that, between seeing the bike and picking it up (about 6 weeks) someone has knocked and broken off a piece of the top fin ( the front corner).I didn't notice on collection so don't have the piece. Can this be repaired at all?
I can do most of the basic mechanics but have no engineering/machineing skills or experience.
Thanks for listerning.
steve.w
#2 PostAuthor: steve.w » Sun Jul 01, 2012 5:48 pm
if the helicoil is done right its fine it can also be done in bike as for fins they can be welded up :D
ross
#3 PostAuthor: ross » Sun Jul 01, 2012 5:55 pm
helicoils are normally fine, problems happen if you take the plugs out / in with a hot cyl head.
for your fin ,i have used an alloy metal in a paste and in the past have repaired fins, cases and a crankcase. you can even drill/ tap it. so file it down to match when dry, its available on the internet/ i think even halfords do a version though i havent tried theirs.
# 364
78 z1r
78 z1r monoshocked
78 z1000 a2
83 z1000r elr
83 z1000r elr monoshocked
z1000puddin
#4 PostAuthor: z1000puddin » Sun Jul 01, 2012 7:33 pm
John,
I have these in two of my plug holes.
http://www.timesert.com/
No issues at all with these, but you do need the head off to fit these,some say you can do it with the head on using grease to catch any swarf - But I would advise against this as there is no guarantee to catch every little bit.
Stu
Zed til Dead
sid123
#5 PostAuthor: sid123 » Sun Jul 01, 2012 7:43 pm
timesert is the way to go :-
look here not too expensive either
http://www.ebay.co.uk/itm/Spark-Plug-Re ... 110wt_1037
Clean out newly cut thread with thinners and put some thread lock on outer thread of insert before fitting ( stops it coming out )
whoosh im gone
PJ
#6 PostAuthor: PJ » Sun Jul 01, 2012 8:17 pm
sid123 wrote:timesert is the way to go :-
Sid, where have you been???
sid123
#7 PostAuthor: sid123 » Sun Jul 01, 2012 10:20 pm
went to club meet last weekend
Now got a new job so life is busy at moment -
still in motorcycle trade - hopefully will be able to sort some benefits out for club members
can't promise anything yet but will do what I can
hoping to get to swancote this week if weather ok
Best wishes
Sid
whoosh im gone
#8 PostAuthor: PAULJAC47 » Mon Jul 02, 2012 6:23 pm
http://www.ebay.co.uk/itm/Pilot-Nose-Ta ... 35bd31bfce
I helicoil but with one of these taps that dont req drilling it uses the plug thread as a guide and cuts a new thread for the helicoil,as a bonus just repaired a sump thread with it works fine,,
steve bowdler
#9 PostAuthor: steve bowdler » Mon Jul 02, 2012 8:17 pm
Hi and welcome to the site :D
KeithZ1R
#10 PostAuthor: KeithZ1R » Mon Jul 02, 2012 8:32 pm
PAULJAC47 wrote:http://www.ebay.co.uk/itm/Pilot-Nose-Tap-For-Helicoil-Inserts-M14-1-25-/230807420878?pt=UK_Hand_Tools_Equipment&hash=item35bd31bfce
impressive never come across them before :)
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
