I know thats not always the actual lift value, but it's all I need ta
Z900/1000 CAM LIFT ADVICE
Can someone tell me how much actual LIFT the standard cams have.... thats the lobe dimension less the narrowest section.
Re: Z900/1000 CAM LIFT ADVICE
Pigford wrote:Can someone tell me how much actual LIFT the standard cams have.... thats the lobe dimension less the narrowest section.
Std cams = 8.4mm.
