standared cam sizes
zman
standared cam sizes
#1 PostAuthor: zman » Sat Apr 21, 2012 8:08 pm
me again :lol:
i want to check to see if ive got lumpy cams.what sizes lobs on a standard engine [z900]
its been board to 1015 so may have z1000 cams.what sizes are these :?:
thanks again
keep thoses wheels turning
#2 PostAuthor: zed1015 » Sat Apr 21, 2012 8:53 pm
All std 900 and 1000 cams are more or less the same lift give or take around .2 to .3mm.
Mk2 cams are around .4 higher lift which is nothing that will cause your problem.
zman
#3 PostAuthor: zman » Sat Apr 21, 2012 8:58 pm
wanted to know what is standard in case thesev are even bigger.
#4 PostAuthor: zed1015 » Sun Apr 22, 2012 11:41 am
Depending on wear, which model and wether inlet or exhaust , std 'Z' cams range from around 7.7mm to 8.4mm lift (subtract base circle from lobe height).
If they are in that 8mm range then they are std .
