zman wrote:yes fitted
firstly Im no mechanic so this is my own experience
from setting the cam timing on various bikes , inc my z1b and gs750, you set it up without the idler wheel tensionors, with the arrows in the right position, tdc mark, number of pins counted etc - and then when apply full tension by way of the idler gear and the rear tensioner after the cams are biolted down - the arrows and tdc generally dont line up exactly again - and that is even with a new camchain, ther is quite a lot of slack and lash in the drive train as a lot of tension is applied.
one thing to make sure is when setting up the front cam arrow marks with the tdc, make sure the cam chain down the front of the camchain tunnel is taught
what you have experinced is probably what the majority of z1s or twin cam motors have after full assy, just remove the idler and tensioner , line up the arrows and tdc marks, re- count the link pins two or three times! and really you cant go wrong
When I did my 1st timing job on the z1b I stupidly set the timing to the f1/4 advamce mark instead of tdc, it ran ok but a bit flat, when I realised that I had made a mistake, I reset it and it was much crisper and sharper
