Vacuum gauges
DaveZ1
Vacuum gauges
#1 PostAuthor: DaveZ1 » Tue Apr 03, 2012 8:53 pm
I wonder if there is anyone in the north east area who would be kind enough to lend me a set of vacuum gauges to sync my carbs?
I dont mind a bit of travelling (within reason) so there would'nt be any postage to worry about.
Just about finished my first Z1 resto (Daves Z1A project) and fired her up for the first time the other day so just need the mixture
checking and the cabs sync doing. Any pearls of wisdom and tips out there on this subject would be gratefully accepted :up
Should I also invest in a Gunson colourtune or play it by ear? for setting the idle mixture. Cheers Dave
Re: Vacuum gauges
#2 PostAuthor: kev edwards » Wed Apr 04, 2012 7:19 am
DaveZ1A wrote:I wonder if there is anyone in the north east area who would be kind enough to lend me a set of vacuum gauges to sync my carbs?
If you are going to invest in a colour tune, why not invest in balancers instead they are not much more expensive, if you are running standard jets and airbox your mixture should not be far out.
Crofty
#3 PostAuthor: Crofty » Wed Apr 04, 2012 9:28 am
Dave, Just got a colourtune 10 minutes ago, £24.99 from Halfords, went halfs with GPRD who is also in York. We are looking at going halfs on a set of guages as well, is York too far for you? Jim
DaveZ1
#4 PostAuthor: DaveZ1 » Wed Apr 04, 2012 8:13 pm
Hello Jim, have seen your help post for which vac gauges to use and I agree the morgan tube type look favorite.
I might just bite the bullet and go buy a set myself just seems a bit of a waste spending fifty odd quid on kit that
spends most of its life collecting dust :roll:
Went on Halfords website and it looks like they only sell colour tune kits for 10mm and 12mm plugs :??
Did you get yours from a local branch :?:
B.T.W. Morgan Carbtune deliver their Carbtune Pro to your door for £57 http://www.carbtune.co.uk/carbpric.html
Baz Swailes
#5 PostAuthor: Baz Swailes » Thu Apr 05, 2012 7:00 am
Hi Dave.
You are welcome to borrow my vac gauges.
I live at Durham and work near Sunderland.
Baz.
BAZ
DaveZ1
#6 PostAuthor: DaveZ1 » Thu Apr 05, 2012 12:20 pm
Cheers Baz, thanks very much :up I will be in touch soon.
