Just doing a freshen up of the the cylinder head on my A4 and while I have the head off I am going to give the bores a light hone and replace the piston rings, motor was still making good compression (I believe this will be first overhaul as the engine had only 25k on it when I imported it) but they're getting done anyway.
From experience, does anyone have any recommendations on what type or brand to get, I will be buying from the states as Prices in the UK are ridiculous, I found two types on Z1 Enterprises site.
http://www.z1enterprises.com/66mm-Kawas ... -4336.aspx
http://www.z1enterprises.com/66mm-Pisto ... 0-193.aspx
Any info appreciated, Cheers, Gavin.
new Std. size Piston rings - Recommendations
If engine is making good compression would advise against fitting non Kwak rings just for the sake of it,25k is not high miles on these motors,just my ten pennorth..Paul J
