I assume it'll be around 20mm or so, but anyone got the proper figure... Its for the 26mm carbs with the "fuel pilot screw" underneath the carb (by the manfold rubbers) - it does NOT have the air screws on the upper section of the carb.
If this figure is not available from a MANUAL - has anyone set their carbs FUEL HEIGHT and measured the float height afterwards
If not - WHY NOT, as it'd be a very useful figure to possess
