Brake indicator light in Tacho
jonhunt
#1 PostAuthor: jonhunt » Sun Feb 26, 2012 7:41 pm
Re fitted my clocks this weekend. The brake light never worked, blown bulb. Now that it has a new bulb it does not go out. tail light bulb is working. Any ideas why
KeithZ1R
#2 PostAuthor: KeithZ1R » Sun Feb 26, 2012 7:50 pm
warning light comes continuos on when rear brake light bulb blown its seeing an open circuit somewhere check the wiring diagram the make sure everything is connected
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
#3 PostAuthor: PAULJAC47 » Sun Feb 26, 2012 7:54 pm
Outage relay could be the problem Jon!! indicator light should flash if lamp has blown,the outage realy if you have one should be mounted near to the coils under the tank,it slips into a metal bracket on rh coil,if its duff they are a bit like Rockin horse crap...
KeithZ1R
#4 PostAuthor: KeithZ1R » Sun Feb 26, 2012 8:01 pm
thanks Paul forgot it flashed its only happened once in 30 years but I knew it did something clever :)
Keith
:bop :gom
mistaken.
jonhunt
#5 PostAuthor: jonhunt » Sun Feb 26, 2012 8:48 pm
Paul, Ill take a look All else fails the bulb comes out :evil:
KeithZ1R
#6 PostAuthor: KeithZ1R » Sun Feb 26, 2012 9:22 pm
ok lets try again it definitely thinks the brake light is on its a starting point to look at
Keith
:bop :gom
mistaken.
Garn 1
#7 PostAuthor: Garn 1 » Sun Feb 26, 2012 10:22 pm
Jon, I seem to remember that when the light stays on, it is trouble with the outage relay unit (beside the Lhs coil)..... I have had a few with that symptom. Don't know where you get a replacement!
Hopefully I'm wrong.
Bruce Sexton
#8 PostAuthor: Bruce Sexton » Mon Feb 27, 2012 2:08 pm
Yes I agree. I had same problem, replaced the relay unit and problem solved. Replacement unit was kindly supplied by a club member at reasonable cost.
Bruce
Why were Z1A's not Blue???????
jonhunt
#9 PostAuthor: jonhunt » Sat Mar 03, 2012 7:12 pm
OK tank came off. There is a small rectangular box under the left coil. Appears to be wired in. :??
#10 PostAuthor: PAULJAC47 » Sat Mar 03, 2012 7:32 pm
Should be on a plug Jon! unplug and see if lamp goes out,only way i know how to check op of these is by substution..Paul J
jonhunt
#11 PostAuthor: jonhunt » Sun Mar 04, 2012 5:35 pm
pulled the plug & the light goes out
#12 PostAuthor: PAULJAC47 » Sun Mar 04, 2012 5:38 pm
Outage relay fault mate,put a wanted on here you never know,Cheers Paul J
jonhunt
#13 PostAuthor: jonhunt » Mon Mar 05, 2012 8:49 am
I assume I can run with the relay disconnected for now. Anyone got one that works?
