bolt hole on z1000 frame
tricky
#1 PostAuthor: tricky » Fri Feb 03, 2012 5:00 pm
hi all, i was mooching round the bike looking for things to do on it tomorrow.
while i was mid mooch, i started wonderin what the 6mm bolt hole is for, that is on the bracing plate, that is welded to the frame top tubes just above the airbox?
the same plate also has an oval hole in it, i had a look through my assembly and prep manual but didnt find anything, is it a throw back from an erlier model ???
thanks for any info, bye for now, bored of washington
garyd
#2 PostAuthor: garyd » Fri Feb 03, 2012 6:41 pm
The LTD bikes fix the tank via a bolt. It may be for that?
Reecy
bolt
#3 PostAuthor: Reecy » Fri Feb 03, 2012 6:45 pm
Tricky,
I think it's for an earth off the loom-can't remmeber what it earths though????????????/
Reecy
RGH
#4 PostAuthor: RGH » Fri Feb 03, 2012 8:42 pm
On the Z1/A/B it's for a clip (same as spark plug wire clip) that holds wiring harness up. On Z900A4 and later it's also for the earthing point for the rectifier.
CAT3
#5 PostAuthor: CAT3 » Fri Feb 03, 2012 8:44 pm
I think the oval hole was for the two breather pipes from the carbs to pass through after which they clipped onto the top of the airbox.
Garn 1
#6 PostAuthor: Garn 1 » Sat Feb 04, 2012 11:02 am
Well RGH & CAT3, you would both get the prize....
RTH is correct, the 6mm taped hole is to hold a cable clip and CAT3 is correct the oval hole is to carry the two breather tubes from the carbs to the air box inlet.
CAT3
#7 PostAuthor: CAT3 » Sat Feb 04, 2012 12:12 pm
Just a point of interest, on my Z900-A4 the 6mm hole has a threaded nut welded to the top of it, but it was never used for anything. I always wondered what it was for.
RGH
#8 PostAuthor: RGH » Sat Feb 04, 2012 12:43 pm
CAT3 wrote:Just a point of interest, on my Z900-A4 the 6mm hole has a threaded nut welded to the top of it, but it was never used for anything. I always wondered what it was for.
It is not a 6mm "taped hole" it is a 6mm welded nut on all models.
CAT3
#9 PostAuthor: CAT3 » Sat Feb 04, 2012 2:06 pm
RGH, that's what I meant to say :D
CAT3
#10 PostAuthor: CAT3 » Sat Feb 04, 2012 2:08 pm
or ........... what I thought I'd said :shock:
RGH
#11 PostAuthor: RGH » Sat Feb 04, 2012 2:17 pm
Sorry CAT3, it was another posting that said it was a taped hole.
CAT3
#12 PostAuthor: CAT3 » Sat Feb 04, 2012 2:19 pm
:rir
tricky
#13 PostAuthor: tricky » Sat Feb 04, 2012 4:31 pm
sorted! welll done lads :D thanks for the replys i had a feeling it might have been something to do with an earlier model.
#14 PostAuthor: Pigford » Sat Feb 04, 2012 5:06 pm
This one, just above the seat latch :?:
KeithZ1R
#15 PostAuthor: KeithZ1R » Sat Feb 04, 2012 5:25 pm
Pigford wrote:This one, just above the seat latch :?:
No Mark that's where the air box silencer holding screw fits
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
