Regulator/rectifier units
can anyone suggest where i could purchase said item (after market) for the Z1-R ? as newtronics (its new company) as read in terry bartons report is shite and i aint prepared to have the zed off the road any longer than need be(rebuild of loom accepted) Thanx
- steve bowdler
Try http://www.electrexworld.co.uk/#2699X0 or http://www.sparxelectrical.com/acatalog ... fiers.html
one of these should help
Recieved this morning said item
check part and invoice says nothing about Z1-R
So i ring them up,spoke to the lady again just to clarify it is for my zed and she confirms
It also comes with connector block so i enquire it will have to be cut does this make any warranty void
No she say,but they have the opposite block with terminals supplied which will be sent free of charge.
so far so good,will check it against the old unit(no connectors ever supplied there) and see if i can fit it in the same place as the old one or find it a new location
Well new unit bigger than the previous one so that(as well as many other places) wont fit there.
So have decided(its the only place i can find to fit with air flow) is directly under the headstock (as on Triumphs) so spent the afternoon designing a bracket to fit. That done its off to the machine shop to get one knocked up and start with the re-wire
