Guys
As the title says
What's the best primer and paint to use when refurbishing a brake master cylinder
Thanks in advance
Reecy
What's the best primer and paint to use on a master cylinder
Karas in leigh can do the anodising.
http://www.karas.co.uk/
The plastic reservoir should come apart from the master cylinder,it unscrews if yours has the round reservoir.If it is tight i have used an oil filter nylon strap wrench to remove it.
Agree with anodising but if you want a low cost alternative, I used Halfords semi gloss black spray paint, rub down with fine wet/dry paper, thoroughly degrease with thinners then apply 2-3 thin coats, not as durable as anodising but job done for £4 (don't get brake fluid on it). In true jap tradition didn't use primer and finish is spot on. Been on for 3 years now. Same applies to switches and even top yoke, have seen brake calipers done but the finish won't stand up to stones etc so powder coat /anodising better for calipers.
AKA John Roscoe. PUM #028
1975 Z1B, 2013 Z800
1975 Z1B, 2013 Z800
