In need of a bit of help!
Got a Mikuni VM28SS carb (Z1000 MKII) where the brass pick-up tube for the choke fuel feed has sheared off.
As there is a small section of brass stub still showing in the carb body does anyone know if the brass pick-up tube is a push fit or screw in ?
Or has anyone had a similar problem & managed to come up with a solution or repair?
Or failing that has anyone got a good No.1 VM28SS carb body that they would want to sell?
Mikuni VM28SS Carb - Choke pick-up tube - help required.
Hi,
I don't have a picture but I can try to explain.
Remove the float bowl & the Brass pick-up tube is sticking out directly beneath the the choke plunger I'm told that it's a push fit into the carb body
anyone show a pic or diagram of the needed part as i'll have one in my scrap set of 28s .[/quote]
Users browsing this forum: Bing [Bot] and 17 guests
