What's the max overbore on STD gpz1100 barrels?
garyd
#1 PostAuthor: garyd » Fri Jan 13, 2012 3:08 pm
Years ago i bored mine to 1170 so I know thta's safe.
But can they go to 1200?
big green bus
#2 PostAuthor: big green bus » Fri Jan 13, 2012 6:17 pm
Anything over 1170 (wiseco) you need liners 1260cc there might be other kits with JE or COSWORTH kits that are ok I think there is a 1198 kit, but not sure who makes them
london calling
#3 PostAuthor: london calling » Fri Jan 13, 2012 9:10 pm
Pretty sure that 75mm (1170cc) is the limit for standard liners.
Also if you go 76mm+ then you'll need to get the crankcase machined.
Jack
garyd
#4 PostAuthor: garyd » Fri Jan 13, 2012 9:51 pm
Thans guys.
One for the future but as I've already done a 1170, then I might as well go the whoe hog & make it a 1260.
Gary
#5 PostAuthor: Pigford » Fri Jan 13, 2012 9:54 pm
garyd wrote:Thans guys.
Gary
The 1260 liners are known to be a bit "fragile" - better off spending on a full Big Bore Block :??
garyd
#6 PostAuthor: garyd » Sat Jan 14, 2012 11:41 am
Can you still get a big block...or is it a case of trawling for a 2nd hand one?
neilbarrett
#7 PostAuthor: neilbarrett » Sat Jan 14, 2012 4:22 pm
google ape performance parts and look for the kawasaki zone
#8 PostAuthor: Pigford » Sat Jan 14, 2012 5:03 pm
Try PITSTOP PERFORMANCE - good ol' Joe Hooper :wink:
