fuel tap
greenZ
fuel tap
#1 PostAuthor: greenZ » Sun Jan 08, 2012 5:23 pm
if you fit a pingel gravity fed fuel tap,instead of a vacuum tap what do you do with vacuum pipe ian
RAYZ1
Re: fuel tap
#2 PostAuthor: RAYZ1 » Sun Jan 08, 2012 5:40 pm
greenZ wrote:if you fit a pingel gravity fed fuel tap,instead of a vacuum tap what do you do with vacuum pipe ian
I would say plug it at the carb end , if not shorten the hose to an inch long still connected to the carb and plug it -
the rubber stoppers that fit on the z1 vacum take offs may fit right onto the carb / tract?
Peter K.
Vacuum fuel tap
#3 PostAuthor: Peter K. » Sun Jan 08, 2012 8:34 pm
You should plug the vaccum connection at the
carburettor side properly. Otherwise is draws air
at this point and does not run properly amymore.
Best regardZ from Germany - Peter
www.z-club-germany.de
2012 Edersee Pics - click
