front brake disc
Redbeard
front brake disc
#1 PostAuthor: Redbeard » Thu Jan 05, 2012 8:33 pm
I'm after a single front disc from any of the following bikes please;
KZ1000-A3 (KZ1000) (1979)
KZ1000-A3A (KZ1000) (1979)
KZ1000-A4 (KZ1000) (1980)
KZ1000-B3 (KZ1000 LTD) (1979)
KZ1000-B4 (LTD) (1980)
KZ1000-C2 (Police 1000) (1979)
KZ1000-C3 (Police 1000) (1980)
KZ1000-C4 (Police 1000) (1981)
KZ1000-D3 (Z1R) (1980)
KZ1000-G1 (Classic) (1980)
KZ650-E1 (LTD) (1980)
KZ650-F1 (1980)
KZ750-G1 (LTD II) (1980)
1979 Z1000ST
LTD Project
#2 PostAuthor: LTD Project » Thu Jan 05, 2012 9:19 pm
Might be able to help you but cannot say for sure until the weekend when I will have time to get to the parts and check that I am not misleading you. Obviously if someone comes up with something in the meantime, fill your boots!
KZ1000 B4 on the road, KZ1000 B4 under serious restoration, KZ1000 B3 waiting it's turn.
GB's old snotter in the operating theatre at present!
Redbeard
#3 PostAuthor: Redbeard » Thu Jan 05, 2012 9:21 pm
No problem mate, appreciate it.
1979 Z1000ST
hillbilly
#4 PostAuthor: hillbilly » Fri Jan 06, 2012 7:27 pm
four hole mount,six hole mount,drilled,not drilled.i have a drilled six hole mount.
Redbeard
#5 PostAuthor: Redbeard » Fri Jan 06, 2012 8:54 pm
hillbilly wrote:four hole mount,six hole mount,drilled,not drilled.i have a drilled six hole mount.
4 hole mount, drilled or not doesn't matter, cheers.
1979 Z1000ST
malc87
#6 PostAuthor: malc87 » Sat Jan 07, 2012 12:01 am
#7 PostAuthor: paul doran » Sat Jan 07, 2012 2:29 pm
Malc thats DK
that disc will very probably be well knackered
PJ
#8 PostAuthor: PJ » Sat Jan 07, 2012 6:34 pm
Z1parR
#9 PostAuthor: Z1parR » Sat Jan 07, 2012 8:07 pm
PJ wrote:http://www.ebay.co.uk/itm/KAWASAKI-Z650-Z900-Z1000-DRILLED-DISCS-/280787711903?pt=UK_Motorcycle_Parts&hash=item416040779f#ht_1578wt_922
Same guy has quite a few other items for sale too .
0172 . Geoff Parr
Redbeard
#10 PostAuthor: Redbeard » Sat Jan 07, 2012 8:49 pm
thanks for the links guys, unfortunately i missed that set pj. i will keep looking. basically i am upgrading the knackered caliper on an early z750 for a gpz unitrak one and it requires a narrower disc. the twin disc zeds are narrower than single disc i have.
1979 Z1000ST
000zeds
#11 PostAuthor: 000zeds » Sat Jan 07, 2012 10:22 pm
Redbeard,I have 2 discs from a Z65B1 and they have been skimmed down to 4.5mm,Are these any good ?
Zeds-R-Us
Redbeard
#12 PostAuthor: Redbeard » Sat Jan 07, 2012 10:53 pm
twozeds wrote:Redbeard,I have 2 discs from a Z65B1 and they have been skimmed down to 4.5mm,Are these any good ?
if they're 4 bolt then they're exactly what i need. i actually only need 1 but if you'd prefer to shift the pair that's fine.
1979 Z1000ST
000zeds
#13 PostAuthor: 000zeds » Sun Jan 08, 2012 4:12 pm
Redbeard , they are 4 bolt , how does £25 + postage for the pair sound ?
PM your details.
Zeds-R-Us
LTD Project
#14 PostAuthor: LTD Project » Mon Jan 16, 2012 8:42 pm
Red
Took slightly longer than I thought, but if you still need it I did find the spare KZ1000 front disc, tucked away under a shed load and a half...
four holes, drilled
Let me know
