Offset sprocket
FreddaAbborre
Offset sprocket
#1 PostAuthor: FreddaAbborre » Thu Dec 29, 2011 4:38 pm
Will mount a rim with a 180 rear tire on my Z1000 A2. For that will I need an offset sprocket, can any one tell me how much offset I need. Plan to buy it from Webike, as I will order an exhaust from them.
Or do I have to measure my self?
Will use a Zephyr 750 swingarm with ZX6R -01 rim.
Z1 Moto Martin
Z1B
Z1000 A1
Z1000 A2
Z1000 MkII
H**** FT500
#2 PostAuthor: Pigford » Thu Dec 29, 2011 4:43 pm
3/8" is OK
I got a brand new 15t for a 630 chain for sale - £25 delivered :wink:
Piggy xx
FreddaAbborre
#3 PostAuthor: FreddaAbborre » Thu Dec 29, 2011 4:59 pm
Pigford wrote:3/8" is OK
Piggy xx
Sold!
BUT I must check what chain I will use. Will go to the garage in 30 min, so later this evening I know!
Z1 Moto Martin
Z1B
Z1000 A1
Z1000 A2
Z1000 MkII
H**** FT500
#4 PostAuthor: Ginger Bear » Thu Dec 29, 2011 5:20 pm
Piggy, for a 180 tyre I would say that a 5/8" offset sprocket is required.
Have you been at the sherry again :? :(h33rs
# 104
sanderz
#5 PostAuthor: sanderz » Thu Dec 29, 2011 5:56 pm
Would of thought a 5/8 offset and also 530 pitch chain would be required for clearance?
What wheel are you using Fred - modern running gear or having a Z respoked?
Modern bikes usually run 530 or 525 pitch so you'll probably need new chain / sprockets.
http://z1ownersclub.co.uk/forum/viewtopic.php?t=894
Hope this is making sense and of some help.
Consider gearing ratios if ordering sprockets (530) 18 / 40 on mine but that could change.
Wots up DOHC
#6 PostAuthor: Pigford » Thu Dec 29, 2011 5:56 pm
Port actually :wink:
Yes as GB says - it's a 5/8" off-set :!:
FreddaAbborre
#7 PostAuthor: FreddaAbborre » Thu Dec 29, 2011 9:02 pm
sanderz wrote:Would of thought a 5/8 offset and also 530 pitch chain would be required for clearance?
Will use a wheel from a ZX6R. Its fitted with a 525 sprocket (http://www.ebay.com/itm/JT-525-REAR-Spr ... 3726wt_908).
The cheapest solution would be to find a suitable 630 rear sprocket for the zx6r wheel (like this: http://www.ebay.com/itm/JT-630-REAR-Spr ... 3726wt_908).
As I have 630 chains in decent condition.
But the weight loss would be sweet. However that would require a everything new; chain, offset sprocket and rear sprocket, all 530. Which means money.
Z1 Moto Martin
Z1B
Z1000 A1
Z1000 A2
Z1000 MkII
H**** FT500
#8 PostAuthor: Pigford » Thu Dec 29, 2011 10:10 pm
My Z1000A2 runs a 180 rear tyre, with a 5/8" off set sprox and a 630 chain, and has done for the last +7 years, no probs :wink:
sanderz
#9 PostAuthor: sanderz » Thu Dec 29, 2011 10:39 pm
FreddaAbborre wrote:Will use a wheel from a ZX6R.
The cheapest solution would be to find a suitable 630 rear sprocket for the zx6r wheel. As I have 630 chains in decent condition.
:up Sorted!
Yeh, unfotunately its all about the money. Keep us posted as it comes together.
Looks like Pigfords offer is the way to go. :D
Wots up DOHC
FreddaAbborre
#10 PostAuthor: FreddaAbborre » Fri Dec 30, 2011 6:32 pm
Pigford wrote:My Z1000A2 runs a 180 rear tyre, with a 5/8" off set sprox and a 630 chain, and has done for the last +7 years, no probs :wink:
Great!
Will take your offset sprocket!
Details in pm.
Z1 Moto Martin
Z1B
Z1000 A1
Z1000 A2
Z1000 MkII
H**** FT500
