when the bolts etc are removed from the oil sump is it just a matter of tapping it with a rubber hammer to loosen it up for removal.
does anyone have any tips
removal of sump
removal of sump
hillbilly wrote:it wont come off if you dont remove the oil filter.
Good tip.
i recently had an issues with a sump bolt (see recent threads in bike help)
i removed sump bolts and gently tapped with a wooden block and away it came. TIP ..............i bought a cat litter tray to catch the oil
Good luck
Good luck
Andy
Re: removal of sump
bunnysZ wrote:when the bolts etc are removed from the oil sump is it just a matter of tapping it with a rubber hammer to loosen it up for removal.
step away from the crowbar !
Re: removal of sump
chrisu wrote:bunnysZ wrote:when the bolts etc are removed from the oil sump is it just a matter of tapping it with a rubber hammer to loosen it up for removal.
And the large flat bladed screwdriver
Keith
mistaken.
Phil Churchett winner 2013
mistaken.
