God it was tight. loads of shite in bottom and on gauze filter.
New sump plug and gasket ready.
Go easy boys but cos im a novice more advice please.
What are correct torque settings for sump bolts.
Gasket that came off appears rubber. new one is normal card gasket material. When applying gasket what is best sealant to use. i assume i apply a little to both surfaces.
finally there is a slight small crack in the sump.(caused by overtightening i suspect) This has NOT gone all the way through and the sump doesnt leak. is there an easy repair. It could have been there years. shall i just leave it.
Once again, thanks for all your comments good, bad and indifferent
its appreciated.
