z1a respray - pinstripes
z1apaul
#1 PostAuthor: z1apaul » Tue Jul 18, 2006 7:47 pm
hi, just got my first z after waiting 32 years it needs a respray can anyone help with the size of the yellow stripe and the pinstripes on the tank please i am in milton keynes and can travel to see one if that is possable or just the sizes would do. thanks,paul
davy thomson
#2 PostAuthor: davy thomson » Tue Jul 18, 2006 8:19 pm
Hi paul welcome to the sight,the stripes on my z1a sizes are top two 10mm, the ones on the side are 7mm and 30mm tapering down to 20mm the taper starts 3/4 from the front of the tank,if you look in the galleries page 1-32 look at hobbo's z1a you will see what i mean.ps the paint work on my bike is original so the sizes should be pretty accurate hope this helps.
Garn 1
#3 PostAuthor: Garn 1 » Wed Jul 19, 2006 12:25 am
ZaPaul, Have to disagree with DavyT, although there was a green & yellow Z1A on the cover of Classic Motorcycle Mechanics sometime last year that has the stipes as he suggests. However, I am strongly of the opinion, after studying those lines for some years and viewing many originals that the top lines (yellow) are 7mm thick and the white side one's are just over is 7mm not quite 8mm. Agree with the wider stipe dimensions.
RegardZ
davy thomson
#4 PostAuthor: davy thomson » Wed Jul 19, 2006 12:21 pm
Well garn got tape and rechecked mine again the top ones my be closer to 9mm,but you would be spliting hairs and as they were hand painted at the factory there is bound to be some variation.
rickman CRR
#5 PostAuthor: rickman CRR » Wed Jul 19, 2006 12:40 pm
C'mon noo Davy, dinae loose any sleep o'er it.....LOL
davy thomson
#6 PostAuthor: davy thomson » Wed Jul 19, 2006 4:29 pm
Well it is a worry colin.
z1apaul
#7 PostAuthor: z1apaul » Wed Jul 19, 2006 7:43 pm
thanks guys for your help and advice its true, if its anything like the triples every one is similar but hardley any the same but at least i should now be about right. paul
