can I use GSXR wheels on a z
malmojoe
#1 PostAuthor: malmojoe » Sun Nov 20, 2011 8:10 pm
After seeing those bikes from Sanctuary etc I am being drawn towards rebuilding my bike like them, but on a much tighter budget. I've bought a nice swing arm and now I'm looking for a nice set of wheels. I really don't know much about what models I can harvest parts from to suit my Zed, but have heard something about GSXR so did an ebay trawl. Loads of decent looking wheels for about £15 a pop. Could I get myself a set of these? also need to know about the forks?
any advice welcome. well most..
#2 PostAuthor: Pigford » Sun Nov 20, 2011 8:29 pm
Bandit 600 wheels are dirt cheap & 17" with a 160 rear, so easy fit :wink:
I happen to have a Bandit 600 s/arm - they're steel so easy to weld a couple of twin shox lugs on them :P
As it happens (Guyz & Galz) I also have a Gixxer front end (RWU) with 17" wheel which I may be persuaded to part with :!:
coldsummer
#3 PostAuthor: coldsummer » Sun Nov 20, 2011 8:33 pm
Pigford wrote:Bandit 600 wheels are dirt cheap & 17" with a 160 rear, so easy fit :wink:
Blimey Piggy, that must be an old 'un?
tlc
International Rep
#4 PostAuthor: tlc » Sun Nov 20, 2011 8:35 pm
Someone will be along much more knowledgable than me but if it`s the Sanctuary style you want then It`s either late ZX or 10 year old CBR wheels. There are RSV wheels of course. Just keep away from 3 spokes. Anything can be made to fit.
Asphalt Cowboy
malmojoe
#5 PostAuthor: malmojoe » Sun Nov 20, 2011 8:38 pm
Thanks, I'll have a look at the bandit wheels and might have the lot of you.
this is the sort of thing I'm after (about 8 secs in) but for a couple of hundred quid :roll: :roll: :roll: :roll:
http://www.youtube.com/watch?v=uHd37msfel0&feature=player_embedded
Simon, you had a couple of recomendations to achieve that Sanctuary swagger...
malmojoe
#6 PostAuthor: malmojoe » Sun Nov 20, 2011 8:41 pm
tlc wrote:Someone will be along much more knowledgable than me but if it`s the Sanctuary style you want then It`s either late ZX or 10 year old CBR wheels. There are RSV wheels of course. Just keep away from 3 spokes. Anything can be made to fit.
thanks Chris
nigel bessant
#7 PostAuthor: nigel bessant » Sun Nov 20, 2011 9:22 pm
Chris, why keep away from 3 spokes?
cheers
Nigel
malmojoe
#8 PostAuthor: malmojoe » Sun Nov 20, 2011 9:34 pm
I didn't like to ask :shock:
tlc
International Rep
#9 PostAuthor: tlc » Sun Nov 20, 2011 10:02 pm
It's your choice Glynn but I feel the look is more important than the practicality.
The 5 spoke OZ or 10 spoke gale speed are what does it for me.
If your budget is as low as mine then I understand.
Asphalt Cowboy
malmojoe
#10 PostAuthor: malmojoe » Sun Nov 20, 2011 10:09 pm
I'll check them out too, most wheels I've seen tonight are 3 spoke though. It's early days yet but I'll start a project thread, or is that shoe string..
garyd
#11 PostAuthor: garyd » Mon Nov 21, 2011 9:16 am
3 spokes are common..therefore cheap. But I'd be quite happy with that look. Best go for ZXR400 wheels.
All the flash aftermarket wheels are 5 or 7 spoke so will look like you've got expensive ones. Older CBR 600s are 7 spoke. And the early VRF750 fronts look good.
I'm in the lookout for RS 250 wheels but have a set from a Zephyr 1100 which will probably ens up on mine.
If you go with kawasaki wheels then the chances are most dimentions will be common.....i.e. disc brake carrier etc.
malmojoe
#12 PostAuthor: malmojoe » Mon Nov 21, 2011 9:32 am
thanks Gary, and everyone, all very helpful info.
#13 PostAuthor: Rich » Tue Nov 22, 2011 7:26 pm
Which ever you go for watch the hub widths, Suzuki wheels are usually narrower hubs than Kawa for the Bandit / SV / GSXR 750 / ZXR etc. Have a good measure of what you want to buy before buying, don't forget to cost disks and calipers etc as well. It may be better to buy the front and rear end from a donor bike and try to sell on the bits you don't want.
Don't buy the first thing that comes along, do your homework and then go shopping. :wink:
spondonges
#14 PostAuthor: spondonges » Tue Nov 22, 2011 8:10 pm
Rich wrote:Which ever you go for watch the hub widths,
Apparently GS500 sprocket carriers are narrower and fit the later wheels
I'd rather be riding my Z1 thinking about God than sitting in a church thinking about my Z1..
