Taffus
Not owned by Herman Munster by any chance?
Dont think so Mark it's too weird for him.
It started out in Scotland near Stirling and then moved to Petworth Sussex back to Scotland for a while i think and at some point was owned by the Dimbelby brothers (TV news pundits)
It finished its working life in a timber yard lugging trees around somewhere.
There are a couple of pictures of the Dimblebys with the car in the lates sixties / very early seventies with what look like afro hair do's.
Jimmock all this talk about wood and no fatty soft??
Couple of bits i missed.
The head of the robot from Lost in space perhaps?
Special low profile bulbs for narrow spaces.
Inner rears were shot so... you get the drill;
Rear outers after major surgery.
The engine is arranged from centre front to left rear. An angle of about 15 degrees. Absolutely no idea why and cant see the justification for it because it brings with it a whole host of problems.
In order to build the weight of the body and panels onto the chassis is needs to be deflected down to at least simulate the load.
So i placed the crankcase and box in and re-arranged the jacking points. If you dont, the progressive adding of weight will give false body lines and shuts when the car goes on the floor.
Yes that is correct crankcases. Its a lower and upper half bolted together with the crank somewhere in between.
The crank is not on the same centre line as the drive train and i think its driving the clutch through a pair of gears with this the mother of all HYVO's
In case you wondered the cut out in the front seats is for the gear lever and for the handbrake which is bolted to a pivot mounted on the side of the gearbox.
Off to get the splinters out of my hands and arms now.
