Viton valve seals
Jappen
Viton valve seals
#1 PostAuthor: Jappen » Sun Sep 20, 2009 7:26 am
Somebody out there used Viton valve seals :?:
Or its better to use orginal Kawasaki seals :?:
I start building a engine for my MK2 using a
Ported z1000j head,PSP1 (old andrews X3 style cams)
APE valves/springs. MTC bigblock 1327cc.MTC 10,5 piston kit.
Falicon crank and Yoshimura undercut gearbox. :evil: :sf
80-Z1000H
79-Z1000MK2
paulmceleney
Chunks
#2 PostAuthor: paulmceleney » Sun Sep 20, 2009 8:03 am
use APE valve seals
hanskloss
#3 PostAuthor: hanskloss » Thu Nov 10, 2011 12:34 pm
Hi Gents, I've sent a question about APE seals availability to Pitstopperformance ang got this response:
"The APE valve seals are not what you want. Neither are the ones that you were looking at when you sent this e-mail. Both are sub-standard. I only carry them because some people want cheap.
The best seals made are Viton and I have them. They are $25.50 a set and shipping to Poland is $6.00.
Do some research of Viton as a material and you will see why these are the
best for this application."
At 30 odd dollars vitons are cheap too. I've read about viton material and it all makes sense but has anyone actually fitted them and used for a longer while so could comment?
Any input much appreciated.
#4 PostAuthor: PAULJAC47 » Thu Nov 10, 2011 12:40 pm
Why change from Kawasaki seals? we know they work!!!!
nanno
#5 PostAuthor: nanno » Thu Nov 10, 2011 5:09 pm
I use Viton seals.
Yes they do work and yes they stay softer for much longer. I also use Viton crank seals on my Jawa and they outlast the standard material by years, even if I store the engine and the crank is not move, they will not bind.
Greg
irhobotolo
Re: Viton valve seals
#6 PostAuthor: irhobotolo » Thu Nov 10, 2011 5:57 pm
Jappen wrote:I start building a engine for my MK2 using a
Is it safe to assume that its not going to be a standard bike then. :shock:
#7 PostAuthor: Pigford » Thu Nov 10, 2011 6:55 pm
I've bought a lot off Joe Hooper (Pitstop Performance) for my Mk.II Sprinter and hes a good lad :wink:
Jappen
#8 PostAuthor: Jappen » Thu Nov 10, 2011 7:17 pm
No its not :D
http://www.z1ownersclub.co.uk/forum/vie ... highlight=
80-Z1000H
79-Z1000MK2
#9 PostAuthor: kev edwards » Thu Nov 10, 2011 7:44 pm
I have used viton seals, not only in engines but also on electro plating lines and the material is bloody good stuff.
#10 PostAuthor: Ginger Bear » Thu Nov 10, 2011 11:20 pm
Joe Hooper = Excellent seller :wink:
# 104
#11 PostAuthor: Rich » Fri Nov 11, 2011 5:31 pm
Ginger Bear wrote:Joe Hooper = Excellent seller :wink:
seconded
Jappen
#12 PostAuthor: Jappen » Fri Nov 11, 2011 5:59 pm
seconded
Agree :!:
I have bougth all my engine parts from him
And he have build my z1000j head.
No problems with him at all :!:
80-Z1000H
79-Z1000MK2
