Engine mount on Z1100 grrr
RALPHARAMA
#1 PostAuthor: RALPHARAMA » Mon Oct 31, 2011 5:58 pm
The bottom front engine mount bolt on the Z1100 shafter won't come out. It's one of the rubber mounted jobbies, and I fear that the bolt has become welded with rust to the sleeve inside the rubber mount.
I have tried beating the end of the bolt with a persuader (four pound lump hammer). I don't sea how heat would help as all that's going to happen is that the rubber will catch fire.
I suspect that the only way is to drill the head and end out; but if there is a less destructive method it would be good to hear it :)
Any help much appreciated :D
Image :D
Ralph Ferrand
#2 PostAuthor: Pigford » Mon Oct 31, 2011 6:04 pm
My Lawson was the same - I kept at it with a lump hammer and it only took 90 mins :??
Taffus
#3 PostAuthor: Taffus » Mon Oct 31, 2011 6:10 pm
I have used an sds drill on rotary stop to drive out stuff like this.
(\__/)
(")_(")Image
Keefleaf
Re: Engine mount on Z1100 grrr
#4 PostAuthor: Keefleaf » Mon Oct 31, 2011 6:33 pm
I have tried beating the end of the bolt with a persuader (four pound lump hammer). I don't sea how heat would help as all that's going to happen is that the rubber will catch fire.ht help
Maybe try aheat gun/paint stripper,[ not naked flame ].Take longer to catch alight,might help?
:fire
#5 PostAuthor: z1bman » Mon Oct 31, 2011 6:36 pm
if you have access to an air chisel spray plenty of releasing fluid on the bolt preferably over a 24 hour period then use the air chisel with the straight pointed drift to vibrate the bolt out . i have used this technique on many stubborn bolts. it is very good for removing aluminium exhaust flanges that have seized onto the studs
#6 PostAuthor: Ginger Bear » Mon Oct 31, 2011 10:03 pm
Go on Ralph, you don't need much of an excuse to buy new tools. :sou
# 104
#7 PostAuthor: kev edwards » Tue Nov 01, 2011 9:27 am
I Use one of those 14 volt hitachi rattle gun type screwdrivers on things like that and to date they are very successful, and of course i have the high tensile sockets and adaptors to go with it.
coldsummer
#8 PostAuthor: coldsummer » Tue Nov 01, 2011 11:09 pm
Ralph you are welcome to borrow my snap-on cordless rattle gun if you like. It WILL shift it.
