Hi there, maybe a dumb question, .but........
Do all the Z1 28mm carbies (ie the "ribbed" and the "ribbless" versions) share the same float bowl gasket?
For some reason I'm thinking they weren't, but maybe I'm getting confused between them and the later Z1B / A4 type.
Thanks!
Bowl Gaskets for early 28mm carbs
I got some of the early type gaskets and later Z1-B types pictured on this link to try and explain the difference.
http://www.ebay.co.uk/itm/230674701727? ... 1555.l2649
As far as I know there are only these two types and the one in the left of the picture does all the early 17mm centre drain plug types.
I did check the explanation bit out with someone on here before I posted the ad so hopefully its all accurate.
Hope this helps.
from Mark
Hope this helps.
from Mark
