Here's a piccy anyway
Padders wrote:I always apply a small smear of copper grease on the threads Simon. also as a precaution I run all the threads through with a tap to clear any contamination.
Looks great and looks like you will have a busy bank holiday.
KeithZ1R wrote:Foget the thread cleaner just get the correct size bolt and run your dremel wiv a cutting disk in it down the threads at 120 deg apart cheaper and much more satisfyingyou have got a dremel Simon
