Z1 Drive Chain Conversion to 530
Garn 1
#1 PostAuthor: Garn 1 » Thu Aug 18, 2011 1:15 am
The standard (usual) Z1 has a 630 drive chain (92 links), with a 15 T front sprocket and a 35 T rear.
I'm fitting a 530 drive chain (110 links), with 18 T front sprocket and 42 T rear. The 530 chain (nowadays) is much stronger, the drive train is a lot smoother and lighter. This configurations maintains the same ratio.
I have one small problem, the supplier of front sprocket gave me a front sprocket without the small tab locking washer hole, but rather has two (diagonally opposite) tapped 6 mm holes. These holes are on a relatively large PCD.
I tried the larger locking nut , however, the spindle shaft seems too short to allow the locking part of the nut to lock. I don't want to buy another sprocket.
Anyone any ideas of how to lock this front sprocket? I believe this, two tapped holes method is used by other manufacturers (Hon*a) to retain the sprocket.
#2 PostAuthor: Rich » Fri Aug 19, 2011 7:25 pm
They use a splined retainer that slips over the shaft splines and then rotates in a groove to "lock" it in place with the 6mm screws - no nut.
See if you can find (or make) a tab washer that locates on the splines then bends up to lock the nut.
#3 PostAuthor: z1bman » Fri Aug 19, 2011 7:59 pm
you could try the lock washer from a er250/gpz 305 belt drive it is the type you are after + does not require a machined groove on the output shaft to locate it. the washer locates on the corners of the nut then is secured to the sprocket by 2 6mm bolts
kawasaki part no 13169-1742 PLATE,LOCK/ WASHER
cost is about £3
Garn 1
#4 PostAuthor: Garn 1 » Mon Aug 22, 2011 6:58 am
Thanks for the help Rich ...... Z1Bman, I'll look further into that belt drive sprocket/pulley holder..... I think the two 6 mm bolts may protrude too far out, touching the alloy casting of the Z1, where the chain oil pump is usually mounted on the Z1.
Home Made Tab Lock-washer for this 530 Sprocket
530 18 Tooth Sprocket
The Assembly
It was a pain in the ass to make this tab washer , however I now just have to lever up an edge to lock the nut into position
#5 PostAuthor: z1bman » Mon Aug 22, 2011 8:56 am
good work garn should do the job. i would put some grease on the lock washer to prevent it from twisting when you tighten the nut
