Ultrasonic cleaner
- coldsummer
Ultrasonic cleaner
I've decided to buy myself an ultrasonic cleaner as a reward for giving up drinking. There seems to be quite a choice, can anyone recommend a good one? Quality of finish/ease of use is more important than price (within reason).
Re: Ultrasonic cleaner
coldsummer wrote:I've decided to buy myself an ultrasonic cleaner as a reward for giving up drinking.
You should be able to buy quite a big cleaner then
LE to JOG on a z900
P.U.M.
P.U.M.
- coldsummer
Jumbo wrote:coldsummer wrote:I've decided to buy myself an ultrasonic cleaner as a reward for giving up drinking.
You should be able to buy quite a big cleaner then![]()
- steve bowdler
wilsonsjw11
I bought one of these last year and it was pretty good, paid about £40 for it. They're easy to use, put the item in, switch it on, choose length of time and whether you want to heat the water. Throw some cleaner in to help it and voila. The hassle is strrpping the part you're cleaning. Main thing to look out for is size and whether the bit you want to clean is going to fit. The one I bought will fit a carb or two if stripped down, but one not four on a backing plate! I got mine from Holland.
What we got here, is failure to comunicate.
GPRD wrote:I bought one of these last year and it was pretty good, paid about £40 for it. They're easy to use, put the item in, switch it on, choose length of time and whether you want to heat the water. Throw some cleaner in to help it and voila. The hassle is strrpping the part you're cleaning. Main thing to look out for is size and whether the bit you want to clean is going to fit. The one I bought will fit a carb or two if stripped down, but one not four on a backing plate! I got mine from Holland.
Would you recommend it? a carb or two sounds a decent size for me does it do a good job? If so what model please.
Simon,
I had one from this lot.....
http://www.walkerelectronics.co.uk/prod ... cbaths.php
Bought the little QC, just big enough to fit one carb body in.
If you really have stopped drinking (lightweight) you could push the boat out & buy something slightly larger.
I've had some excellent results with mine.
Simon follow these steps ................. 1 ] buy small ultrasonic cleaner
2 ] buy rubbish southern beer.
.... 3 ] when its gone flat after 3 minits dont throw it away
... 4 ] place glass with beer containing said flat beverage into cleaner and switch on for 5 seconds
Hey Presto no more flat beer
... 5 ] send stuff to professional ultra sonic cleaner to avoid disappointment
Keith
mistaken.
Phil Churchett winner 2013
mistaken.
- coldsummer
Rich wrote:GPRD wrote:I bought one of these last year and it was pretty good, paid about £40 for it. They're easy to use, put the item in, switch it on, choose length of time and whether you want to heat the water. Throw some cleaner in to help it and voila. The hassle is strrpping the part you're cleaning. Main thing to look out for is size and whether the bit you want to clean is going to fit. The one I bought will fit a carb or two if stripped down, but one not four on a backing plate! I got mine from Holland.
It wasn't Holland, it was Belgium, near enough eh!
Got one off these people, very much like this, but this is slightly bigger http://www.ebay.co.uk/itm/Professional- ... 3cb5761bb8
It works a treat, you've got to give it a few goes though. Its automatic so it turns itself off. I'd reccommend it, but there will be others out there better, but this one does the job. Don't forget the cleaner.
I bought a 6 litre one off evil bay similar to this a couple of years ago.
http://www.ebay.co.uk/itm/Stainless-Ste ... 2310d93510
Stainless steel, adjustable timer, variable heater , works a treat.
I can get a couple of carb bodies in at once + a few small parts.
I would buy bigger (to fit four carb bodies) if i did it again as i use it quite frequently.
Mine was £160 at the time so prices haven't moved on that much but it looks like that they aren't getting any cheaper.
- paul doran
