Now 2 & 3 not firing
I took Pauls advice and tried to swap leads 1&4 because 4 wasn,t firing, but the leads are too short. So after replacing them, i started the bike and both 2&3 arn't firing, Does anyone have any idea?
i has similar problems with my 11R yesterday, one minute it had no spark at all, then it'd fire on 1/4, then on all 4, then only on 2/3......
it was the connector plug from the ign pick ups, it all looked ok but once i pulled it apart i could see it was full of horrid green corrosion !!!!
double check all connectors 1st, it could be something nice and simple
