carb balancing
brian 450
carb balancing
#1 PostAuthor: brian 450 » Mon Jun 20, 2011 6:32 pm
Does any one know what order i need to balance my flatsides? number 3 is fixed.
CAT3
#2 PostAuthor: CAT3 » Mon Jun 20, 2011 6:39 pm
You just balance 1,2 & 4 to match 3, I would guess.
Small adjustments are best, as you increase say #1 the other three will decrease & vice versa depending upon which way each carb needs adjusting.
I find it best to adjust the carb that's furthest out first & gradually bring each one to match the master carb.
brian 450
#3 PostAuthor: brian 450 » Mon Jun 20, 2011 7:34 pm
Thanks that's what I thought. I had a go tonight but when I did the last one all the others dropped and the revs went up.
