engine transplant
engine transplant
I'm going to modify my Z250 Scorpion, 1980 W reg.
Can any one tell me if an engine out of a Z1000 will fit and if so what other mods will I need to do?? I'm hoping to fit a brand new genuine Kawasaki 4 in to 4 exhaust system to it as well ?
Cheers guyz.
Jimmock.
Cheers guyz.
Jimmock.
Jimmock.
I hate people I don't like !
FER wrote:You would be better fitting the engine from a 900 as it's smaller and this would help in fitting the 4 pipes![]()
fer
Hi Fer,
Thanks for help / info.
Have you done this mod before??
How much "smaller" is this 900 engine in comparrison to the 1000 engine I have?
Jimmock.
Jimmock.
I will measure everything up tomorrow as I have an old 73 900 too.
I might use this engine for the Scorpion and put the 1000 motor into the 73.
Even though it is 100cc smaller it should still be an improvement over the original 250 motor.
Jimmock.
Jimmock.
Jimmock.
Keefleaf wrote:"All or nothing"
I put a Z1300 engine in a Kr1s,only special tools needed were tyre levers and an old spoon.
I have all this equipment myself.
Should be straight forward then??
Jimmock.
Jimmock.
Would you like a Vance and Hines sidewinder exhaust to go with this modification.
Though you will have lose the kick start, fit rear sets, and possible modify the brake lever as well. Depends on what look you are hoping for.
Hi Guyz thanx for all the info, help, advice and support.
I'd certainly be interested in the rear sets Adrian.
I'm still hoping to "modify" the 4 into 4 to fit the Scorpion frame, so I'm not really interested in the side winder.
I'm intrigued and interested in this upside down engine idea. I have an early CB750 motor in the workshop, I could use the scavanger pump and dry sump system to enable the upside down idea to work.
I'm going to make a really nice pair of side panels out of chequred aluminium plate.
I'm open to any more suggestions or comments guyz.
Jimmock.
Jimmock.
Jimmock.
I've seen a few interesting kawa 2 strokes recently, grafting cases together to make kh500 v6 and inline 4 666cc etc. Now why don't you couple two Z900 together to make a V8 1800 that has exhausts that go 1 into 4 (instead of 4 into 1). Then you could have 32 exhausts, think of the noise it would make and you could put it in CMM magazine.
