ZX1100 engine with 1000r frame
dimble
#1 PostAuthor: dimble » Mon Feb 22, 2010 12:44 pm
One question while assembling the 1000r frame and the ZX1100 engine. the ZX is going to run with carbs instead of injection. Does anyone know if i can use the wiring from the 1000R with only the specific IC IGNITER of the ZX (electronic advance on ZX instead of mechanical on the 1000R) :wink:
#2 PostAuthor: Ginger Bear » Mon Feb 22, 2010 1:38 pm
I'll look forward to seeing what other people think, my latest project involves fitting a ZX-1100 (GPz1100A2) engine into a Z1000J frame. I plan to use the original GPz1100 loom & ic ignighter. I would be interested to know what other options are available too.
# 104
london calling
#3 PostAuthor: london calling » Mon Feb 22, 2010 1:43 pm
I think it should work but won't give the optimum performance that the ZX ignition unit would.
I know that by fitting GPz igniters to the GT 550/750 models,top end performance is improved by allowing more revs.
Personally I'd rather fit the ZX ignition into the 1000R wiring.
Jack
dimble
#4 PostAuthor: dimble » Tue Feb 23, 2010 6:33 am
Some progress here, i took out the igniter from the 1100R and apprently the only specific part is the little wiring from the ZX1100 igniter that is divided in two branches (one goes to the left side of the battery ,the other goes to the pulse sensors)..it should work :)
blackdog3
ignition
#5 PostAuthor: blackdog3 » Tue Feb 23, 2010 9:22 pm
no it wont work. you will need a dyna 2000. im just finishing the conversion now
dimble
#6 PostAuthor: dimble » Fri Feb 26, 2010 3:13 pm
Do you know more about why it won't work? :cry:
steve.w
#7 PostAuthor: steve.w » Sat Feb 27, 2010 5:22 pm
mine has zx ignition system running on z1000 j wiring it runs fine..
dimble
#8 PostAuthor: dimble » Thu Mar 18, 2010 12:55 pm
Actually it works with a minor mod on the 1000R wiring. You need to add a little "diode" (sorry i don't know the word in english) as it is on the ZX1100 wiring....and it runs well.... :wink: :wink:
#9 PostAuthor: Rich » Thu Mar 18, 2010 6:44 pm
Diode is English as well :wink: probably to stop reverse voltages destroying the IC on the feed wire.
