tacho drive seal
bunnysZ
Granny Magnet
tacho drive seal
#1 PostAuthor: bunnysZ » Thu Jan 28, 2010 4:19 pm
have a leaky tacho drive from the engine.
is it just the kit i need 1 oring and plastic bit to fix, and do i need to remove the cam to get at it.
Z1B Alan
#2 PostAuthor: Z1B Alan » Thu Jan 28, 2010 4:59 pm
All you need to do is undo the retaining screw pull out the drive {it may require turning slightly to ease it out and when replacing it } replace the o ring and replace with a little oil on it for lubrication. Did mine a couple of years ago now drier than an arabs fart.
ROZZER
#3 PostAuthor: ROZZER » Thu Jan 28, 2010 6:03 pm
As our kid says, dead easy, no need to remove cam, seal just levers out and o'ring is, well, just an o'ring, so a piece of pish. 'fraid I don't know anything about how dry our middle eastern friends farts are, frankly it worries me that my brother does!!!!!!!!!!!!!!!!!!!!!!!!!!!!
AKA John Roscoe. PUM #028
1975 Z1B, 2013 Z800
Users browsing this forum: Google [Bot] and 24 guests
