Powdercoating a master cylinder question.
Crofty
#1 PostAuthor: Crofty » Fri Jan 08, 2010 12:11 am
I need to get my master cylinder refinished, ideally black powdercoat. No problem normally, but this is the m/c with the little round window for keeping an eye on the fluid level. The guys that powdercoated the rest of my stuff, thought it might be a problem when heated up (200 degrees) in the oven they use.
Anyone out there had their m/c of this type powdercoated? Can you get hold of the little window seperate, like you can with the engine oil windows that go in the clutch covers, if it goes tits up?
I guess I could respray it and try to match the finish if a problem. Cheers, Jim
coldsummer
#2 PostAuthor: coldsummer » Fri Jan 08, 2010 12:29 am
Crofty there are probably better options than powder coating. Mikey might have some advice ref anodising....
Taffus
#3 PostAuthor: Taffus » Fri Jan 08, 2010 12:32 am
TLC has been through this process, he'll be along in a mo...
(\__/)
(")_(")Image
mikey
#4 PostAuthor: mikey » Fri Jan 08, 2010 6:53 am
coldsummer wrote:Crofty there are probably better options than powder coating. Mikey might have some advice ref anodising....
I have anodised a few of these with good results, doing 3 at the moment for club members, only problem is steel wont survive in an anodising tank, and i believe im right in saying that the sight level glass has a steel reinforcing ring round it?
Crofty
#5 PostAuthor: Crofty » Fri Jan 08, 2010 9:19 am
You are indeed correct Mikey, it looks like a stainless ring as its shiny and has no corrosion. Jim
Robw
#6 PostAuthor: Robw » Fri Jan 08, 2010 9:42 am
I got my master cylinder powder coated, it has a small plastic window and everything was fine.
Rob
Crofty
#7 PostAuthor: Crofty » Fri Jan 08, 2010 9:58 am
That's good to know Rob. After sleeping on it, I think I will risk it. If it does get damaged or disturbed, I will source another used m/c thats knacked and cut the window free and see if I can replace it. I will post the result when done. Thanks, Jim.
Crofty
#8 PostAuthor: Crofty » Fri Jan 08, 2010 11:19 am
Came in from the shed as its freezing and started Googling re master cylinders and powder coating with glass windows and
http://www.newrivercyclesalvage.com/sight%20glass.html
Computers are amazing, mind you I've not contacted them yet.
Still prefer to try taking one out of an expired genuine m/c.
