Carbs and Caliper bits
I am after a couple of bits,a set of needle valves for Z1B 28mm carbs,although I only actually need one. I think they are the same across the range including Z1000s.Also I want to put on a twin discs, so any of the parts required I am also interested in. Thanks. Sean.
