Side panel badge removal
Redbeard
#1 PostAuthor: Redbeard » Sun Dec 13, 2009 9:40 pm
Is there an easy way to get these off cos i dont want to snap the pins on the back of the badge? They are on there very snugly. Or is it a case of WD40 and taking my time? Cheers.
1979 Z1000ST
Pasc
#2 PostAuthor: Pasc » Sun Dec 13, 2009 9:50 pm
If you are taking them off to re paint the panels then I would steer clear of spraying them with wd40 or any other lubricant. It' soak into any spots of bare plastic and pobably lift your new paint. Also any thing with silicon in it will be a bastard to ret rid off and will create fish eyes in your top coat.
Redbeard
#3 PostAuthor: Redbeard » Sun Dec 13, 2009 9:53 pm
Thanks Pasc, useful to know cos I might have them sprayed.
1979 Z1000ST
z2.john
#4 PostAuthor: z2.john » Sun Dec 13, 2009 10:01 pm
I just use a flat blade screwdriver and work gently side to side, about half a mil a time each side. The clips will ping off OK (well they did on mine!)
Redbeard
#5 PostAuthor: Redbeard » Sun Dec 13, 2009 10:16 pm
ok John cheers, will stick at it. might try warming the clips too. they are on there good and proper!
1979 Z1000ST
Steve Cooke
#6 PostAuthor: Steve Cooke » Mon Dec 14, 2009 4:25 am
Did they have the retaining clips on them? If not I would check that they are not stuck on with silicone or something before pressing too hard on the pins as they often are, you can use a thin blade or wire to check.
Redbeard
#7 PostAuthor: Redbeard » Mon Dec 14, 2009 8:47 pm
Steven, they appear to just have the clips as once i get them looser the badge comes free from the panel. I'll check with a blade to be sure once the clips are off. thanks.
1979 Z1000ST
