Thank's for any imput guy's!!
Fork upgrade??
Magik
Fork upgrade??
Well it's time to buy the shock's for my renovation ('78 KZ1000 A2) now I have allways intended to use Ohlin's rear shock's but looking about at other renovation/upgrades it appears in my inexperiance at this sort of thing that I omitted to take into account the 'handle-abiliy' of the rest of the bike when making this choice
. I have regretably,in retrospect,not strengthen'd my frame and am using the standard front end so my question is; is it still worth the 400 quid i'll be spending on the Ohlin's,ie will I still get the benefit of the Ohlin's with a 'bendy' frame? and if so it will presumably be benneficial to 'upgrade' the fork's and for this I suppose i'll be using progressive spring's? but what about the grade of oil and do I also need to replace the damper rods, if so what with????
Ohlins are money well spent if you intend to keep em/bike for some time, or at least clock up a few miles. You may be able to get some 2nd hand, which will save ?????'s and if necessary they are fully rebuildable.
Like any set up, the WHOLE caboodle needs doing to get max benefit, and any old Zed aint the bike for that. BUT, they look COOOOOOOL
- big green bus
- london calling
Magik
