yet another build in the works
tm53chev
picked up a stripped down 78 Z frame with a 74 Z1E 900cc bone stock engine with 18K on the odomiter. frame neck is cut, braced and set at a 38deg rake. have installed a custom built 8 "over rear swing arm. 160 rear tire, 94" over all length, custom built rear fender, 3 stage fully adj 75hp max NOS kit to install, back cut trans, ceramic coated piston tops to withstand the NOS and NOT burn a hole in the piston, shift light, gear indicator, fully adj drag race electronic ignition, front air damn, floor boards. will be all black paint job, custom aluminum rims, stainless brake lines and anything else I can pull off the shelf for some bling(chrome). need help again posting pics...anyone willing to help out an inept PC user here???
- Administrator
- Site Admin
