I'm in the middle of building a Zed 750 race bike(see projects) and I've stripped down the loom and have removed the alt./flywheel.On the CDi everything is straight forward except for one wire which goes through a diode.Does anybody know whats its purpose is ???????
cheers the noo Brian #88 2B'z Racing
Running Total Loss Ignition
#88
The diode will be to stop reverse voltage going back into it when the magnetic field of the starter solenoid collapses. Leave the diode on it and it will need either connecting to Live or earth. Trace the starter circuit to see if it goes to earth (black/yellow) or +ve (brown).
Is there a separate feed wire, usually brown but may be red into the ICU,
I assume you are not going to run a starter motor!
