NUMBER 7 BOLTS wanted
bedlow1
#1 PostAuthor: bedlow1 » Sun Sep 27, 2009 6:45 pm
Can any one help me 3 number 7 bolts needed, can get them refurbed so rusty not a problem
need 2 for the handlebar mounts for the master cylinder and 1 for the clutch perch.
zedrider
#2 PostAuthor: zedrider » Sun Sep 27, 2009 9:08 pm
i could be wrong . but i beleive the bolts with 7 on the end are suzuki
zed
compo z1r
Re: NUMBER 7 BOLTS wanted
#3 PostAuthor: compo z1r » Sun Sep 27, 2009 9:54 pm
bedlow1 wrote:Can any one help me 3 number 7 bolts needed, can get them refurbed so rusty not a problem
hard to get hold of, can get no 4's in 6mm. no 7's in 8mm and above. what
length you after, 25 or 30mm.
THE ORIGINAL TARMAC TERRORIST
Z1OC # 886
RB
Mine's a triple!
#4 PostAuthor: RB » Sun Sep 27, 2009 10:20 pm
The number on the head of the bolt is it’s tensile strength, they are used on all Japanese bikes over the period, the “7’sâ€￾ are used in places where security is important ( bit of overkill on the clutch perch) The “4’sâ€￾ are also a common sight on Japanese bikes. Anyway, Back to the plot – the “7’sâ€￾ requested are in a chrome finish, and unfortunately they often come with a captivated flat washer which makes them even rarer – and just to cap it all there are 4 different styles of font on the “7â€￾ figure throughout the 1970’s 2- what year "7's" are you after ?
Lifes too short . . .
Steve Cooke
#5 PostAuthor: Steve Cooke » Mon Sep 28, 2009 2:40 am
Graham I've got two no.7 bolts with the captivated washers they are 25mm and a no. 4 bolt with captivated washer which is 30mm, they will need a rechrome. Your welcome to them if you want, if any use to you PM your address and I'll post them straight off to you.
Couldn't tell you which font they are though. :)
MaineKZ
#6 PostAuthor: MaineKZ » Mon Sep 28, 2009 7:37 am
Steven Cooke wrote:Couldn't tell you which font they are though. :)
Long as it's not 'Baskerville Old Face' bold - you should be OK :roll:
KeithZ1R
#7 PostAuthor: KeithZ1R » Tue Sep 29, 2009 9:01 pm
AARRGGHH I just use to throw the feckers away :lar :lar :grr :boom
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
mikey
#8 PostAuthor: mikey » Tue Sep 29, 2009 10:00 pm
My tatty winter hack GS650 is covered in no 7 bolts
maybe the bolts are worth more than the bike :shock:
