Standard(ish) wheel re-building
Surfdeneige
#1 PostAuthor: Surfdeneige » Wed Sep 16, 2009 5:05 pm
I'm looking to get Hagon or someone to rebuild my existing hubs with new 17" rims and spokes. Anyone done this? I'm wondering if there are any pitfalls and also how wide a rim and tyre can I put on the back with the standard setup (Swinging arm) using offset sprockets? Again any pitfalls I should be aware of?
A ken fit like!
debben1
#2 PostAuthor: debben1 » Thu Sep 17, 2009 12:04 pm
You can go to 3.5 inch rim with out offsetting sprockets, but the tyre (140 section ) may rub the swing arm when pushed fully forward, you will either need to replace the arm or limit the chain adjusters so that the wheel can not travel fully forward, as you are fitting a 17 " rim this may improve over my 18 ", I fitted a different arm which was a little longer and a 130 tyre, Regards, Steve
Surfdeneige
#3 PostAuthor: Surfdeneige » Thu Sep 17, 2009 2:06 pm
Thanks for that.
It appears that if I use a 17" rim I am actually further restricted in tyre choice due to being tubed although it seems I can get a supermoto rim that might do the job. Seems like it might all be more trouble and expense than it is worth. Still fancy getting the rims and hubs in black but again is it worth the expense?
A ken fit like!
debben1
#4 PostAuthor: debben1 » Fri Sep 18, 2009 11:20 am
I run inner tubes with both my Z's, one has a 3.5 inch rim, the other is 5.5 inch rim and a 180 tyre, just make sure you change the tube every time you change tyre as the inside of the tyre wears the inner tube, the wear is not a lot but its not worth taking a chance for the price of a new tube
Surfdeneige
#5 PostAuthor: Surfdeneige » Fri Sep 18, 2009 2:47 pm
Are these specific tyres or you just run any tubeless tyre with a tube inside?
A ken fit like!
london calling
#6 PostAuthor: london calling » Fri Sep 18, 2009 5:05 pm
Tubeless tyre with a tube inside should be fine.
Just use a good quality inner tube.
Jack
