Anyone install tapered bearings?
				KenC
- Bruce Sexton
Big screw driver grind to a sharp wedge at end then bash it in so wedge forces bearing up slightly then you can get purchase on it with screwdriver and using hammer bash it off, hard taps moving screw driver between each tap to opposite side to keep it as square as possible.
Sounds crude but works.
Garn I did not think you put shim washer on with taper bearings, I put bearing on untill it seated then just stretched rubber washer over it.
