size of shim
zedrider
size of shim
#1 PostAuthor: zedrider » Thu Sep 10, 2009 7:30 pm
hi gang does any one out there know the diamitor of a cam shim mine are 29mm the spare my mate had were 29.4 any ideas ?
zed
bigmac103
#2 PostAuthor: bigmac103 » Thu Sep 10, 2009 7:54 pm
Z1 engines have 29mm.
Lost in the desert somewhere
zedrider
#3 PostAuthor: zedrider » Thu Sep 10, 2009 8:41 pm
many thanks my mate was convinced they were the same as gs1000 shims , guess he was wrong :-)
zed
bigmac103
#4 PostAuthor: bigmac103 » Thu Sep 10, 2009 8:54 pm
I thought it was Suzuki's that had the 29.4mm diameter, just wasn't sure!
If you need some shims just let Jerry (El Presidente!) know and you can do a swap.
zedrider
#5 PostAuthor: zedrider » Thu Sep 10, 2009 10:25 pm
sure do i need a 2.50 . one inlet is a little too tight .
zed
