Thought i was rally getting some where when, over christmas i got it running and ready for MOT, then onwards to get it registered.
I got a bit concerned that the DVLA might demand to see it at registration and give it a Q plate because it was going to have a zephyr front and rear end on it but with excellent help from Jerry Humpage (thanks again Jerry) so i put th estandard back end in again and got it MOT'd like that-legged it down to the DVLA and put me papers in--th elady tehre coul dnot have been more helpful and they weren't arsed about seeing it so i had worried for nowt.
Any way got my '78 plate 3 days later and got about putting some miles on it
rides good--oh ok it rides ok now --cos i had to change the clutch plates and springs the originals were un servicable
luv it
now i have flung the zephyr 750 rear end back in and found out the chain ain't long enough now--get one at stafford this weekend and set the back brake up and then it is as finished as it will be getting!!!!job done
Need to put more miles on it, i have done about 500 since i got the plate in january
OK---so it's not turned out as "trick" as the one i copied but its ok ish and i know it aint original-- for original i have my Z1R and the Z1000A2a and i r appy
don't know if i'll do another but maybe
What do you guys think??????
Steve Rees
