Project Racer
Zomerset Zed
Project Racer
#1 PostAuthor: Zomerset Zed » Tue Oct 04, 2016 6:11 pm
I have just purchased this lovely thing:
Not very good photos im afraid but it was a dark night in a barn in deepest Somerset :wink:
As many of you will know its an ex. Phase 1 (my neighbors) P&M framed Z1170 hybrid motor endurance race bike :P
General spec. is:
Frame 142, last frame they built, not been used, just been painted.
Freshly rebuilt 1170 Graham Salter with GPZ worked on head, Big valves, Wiseco pistons, welded crank, undercut gearbox.
Classic ally Dymags
Brembo discs
AP calipers
Steel fabricated P&M yokes
Marzochi forks
Falcon shocks
Also comes with:
Ally endurance tank 17l
Harris full fairing
Stainless 4:1 and reverse megaphone
Keihin CR carbs and bellmouths
Krober tacho
Needs:
Ignition system
Ignitor housing
LH side gen engine case (fabricated/machined)
Gear linkage
Clutch actuator and perch/cable etc.
Rear brake master cylinder/bracket hoses etc.
Oil cooler and hoses and engine connections/brackets etc.
Fairing brackets
seat unit
Chain and sprox
Front mudguard
Paint
Lots of odds n sods!
Heres a pic of its sister :D
Spot the "mistake" :?:
Re: Project Racer
#2 PostAuthor: zed1015 » Tue Oct 04, 2016 6:25 pm
Obviously a Suzuki with delusions of grandeur.
#3 PostAuthor: Al » Wed Oct 05, 2016 9:50 pm
Vary nice indeed.
Zomerset Zed
#4 PostAuthor: Zomerset Zed » Thu Oct 06, 2016 9:03 am
Very good :wink:
HowieD
#5 PostAuthor: HowieD » Fri Oct 07, 2016 4:55 am
Envious doesn't cover it !
CD185, Maggot, Z1-R, Horace
martinz1000r
#6 PostAuthor: martinz1000r » Fri Oct 07, 2016 9:08 am
Will we see you at Spa and Donnington next year with the other track focused Z's?
Zomerset Zed
#7 PostAuthor: Zomerset Zed » Fri Oct 07, 2016 12:06 pm
It is the intention to take it initially short circuit racing, then may be endurance if i can get a good enough team together. Already have a good mechanic and another good rider. I have a lot to do as i tend to work on large engineering contracts through the dark months, maybe away from home etc. which makes it difficult to work on the bikes.
I think for next year i will be doing some racing and track-days and maybe some of the Belgian classic events like Chimay, Geddine etc. as i love the relaxed nature of those races :shock:
I need to find some more room for bikes first :roll:
Zomerset Zed
#8 PostAuthor: Zomerset Zed » Fri Oct 07, 2016 12:07 pm
But you have Horace :!:
Gus
Re: Project Racer
#9 PostAuthor: Gus » Fri Oct 07, 2016 12:35 pm
I've been down to Phase 1 and used to mechanic for Team Glam Racing against Russel and the boys.
Peter is as hard as a rock and would wring the neck of their P&M's usually to podium places.
He was or still is a fighter pilot I believe.
Myth, story or truth has it that he "borrowed" a fighter one day and went and "buzzed" the start finish straight at one of the tracks he was racing at.
Gus
"Set the GRINDER on it"
tlc
International Rep
#10 PostAuthor: tlc » Fri Oct 07, 2016 3:19 pm
Zomerset Zed wrote:if i can get a good enough team together.
You'll need someone to tell you which parts are not standard.
I'm your man - if you have a parts book that is.
Asphalt Cowboy
Users browsing this forum: No registered users and 4 guests
