Z650 refresh...
MDM
#121 PostAuthor: MDM » Thu Aug 11, 2016 8:11 pm
Like I said earlier, to get some decent chain clearance I was going to have to notch the inside of the frame rails or give them a twatting with a big hammer. I chose the former, mainly because I didn't want to get too giddy with the hammer and end up breaking things. Again.
I'd wrapped masking tape around the frame rails when it was built up and with a chain in place, so I could see where I needed clearance. With it all stripped down, I cut a piece of 40mm square box section steel, and split in lengthways to get two pieces of C section.
I clamped a piece on the inside of the frame, parallel with the bracing added in a previous life, and marked it up for cutting.
MDM
#122 PostAuthor: MDM » Thu Aug 11, 2016 8:13 pm
Then I got the angle grinder and files out...
And tried out one of the C section pieces for size, before marking it out and cutting it down to suit.
MDM
#123 PostAuthor: MDM » Thu Aug 11, 2016 8:15 pm
And then proceded to do the same thing for the lower chain run.
MDM
#124 PostAuthor: MDM » Fri Aug 12, 2016 9:15 am
And then I took the frame to Dave Dunlop at FastByMe turbo systems, so that he could do some welding which would be of far, far better quality and structural integrity than I will ever be able to manage...
And the end result...
And he also blue-glued the shock extension pieces in place as well
Now I need to clean the frame up and get some paint over it.
ollie
#125 PostAuthor: ollie » Fri Aug 12, 2016 11:51 am
some great work there and nice use of the paint stripper gun :lol: :up
sanderz
#126 PostAuthor: sanderz » Tue Aug 16, 2016 5:26 pm
Quality work all the way, top job :up
Wots up DOHC
#127 PostAuthor: Pigford » Wed Aug 17, 2016 5:07 pm
sanderz wrote:Quality work all the way, top job :up
+ 1 :twisted:
MDM
#128 PostAuthor: MDM » Thu Aug 18, 2016 8:46 pm
Thanks fellas! :D
The frame ready for a coat or three of shiny black...
And with that done, it was delicately slipped over the painted engine.
MDM
#129 PostAuthor: MDM » Mon Aug 22, 2016 12:52 pm
I'd painted the original cast Mr Turbo plenum a few years ago (ahem), and it was looking rather scruffy, so with the engine now all black, I decided that the plenum could go back to the original finish, so started cleaning it up
With the added side effect that the Mr Turbo logo would be highlighted
Big Fluff
#130 PostAuthor: Big Fluff » Tue Aug 23, 2016 12:38 pm
Dave. If you want a set of 4 composite gaskets for the inlet to plenum chamber let me know and I'll drop a set off FOC mate. :wink:
MDM
#131 PostAuthor: MDM » Tue Aug 23, 2016 2:17 pm
Funnily enough, that is exactly what I was looking for in the shed last night! If you could mate, that'd be greatly appreciated! ;-)
MDM
#132 PostAuthor: MDM » Fri Aug 26, 2016 1:04 pm
Updates may get a little sporadic over the next few weeks as I'm having to pack stuff for a house move, but things will still get done as I need the bike to be in one lump for the move...
In the meantime, I popped over to see Keith at Nasty Paint in Birmingham to pick up my finished bodywork. Here's a sneaky peak...
#133 PostAuthor: Pigford » Fri Aug 26, 2016 2:33 pm
Bling-king Hell .... that looks perty :party :pop
MDM
#134 PostAuthor: MDM » Mon Aug 29, 2016 9:11 pm
They say that the devil is in the details, so I got myself a replacement sidestand bolt in stainless, and gave it a taste of the polishing mop...
Is Vic There
#135 PostAuthor: Is Vic There » Mon Aug 29, 2016 10:21 pm
Nice work, great welding and the tank colour is stunning :D
Users browsing this forum: Bing [Bot] and 4 guests
