Z800 Cafe Chopper Fighter thing...
Hello all.
Yes, the world's longest Z build is alive and well, just been in hibernation due to all kinds of boring nonsense.
BUT! I have to get it on the road this spring as the garage where the build is kept is being demolished. So even if I don't complete it myself I'll hand it over to my engine builder to complete - he also does lots of custom work / fabrications so hopefully it will be on the road by April!
A quick question to get the ball rolling again.
I'm just putting the finishing touches to the loom which is made from scratch. I'm wiring in the Reg/Rec and have a few questions about cable colours and how it plugs in.
I'm using an aftermarket Reg/Rec for a Z650 with 3 Yellow wires, 1 Brown, 1 Black and 1 White. Can anyone confirm that the below is correct:
3 Yellows TO Stator / Generator
1 Brown TO Battery+ terminal - This is the charging wire and should be fused?
1 Black TO GROUND - Direct to Battery- Terminal or any good ground point?
1 White TO ? This is the control wire I think to regulate charging current - where should enter the circuit? I'm using keyless ignition managed by a MotoGadget unit so the ignition circuit is not straightforward.
Help appreciated! Pics on the way.
Another quick Q.
Want to power this thing up and check all circuits but the M-Unit requires a switched 12V to the LOCK terminal to actually switch it on - even though its connected to the battery.
However, I don't have an ignition switch and the keyless remote is not at the garage.
How can I 'improvise' a switched 12V+?
Direct + from battery do the trick? Or am I sending all the cranking amps down too thin a wire...?
Thanks lads - got it working. This sucker will be ready to fire up soon as it will be off to Debbens for a carb set-up and some minor bits and bobs and then MOT time! Here's a short viid:
https://www.youtube.com/watch?v=XXQFkbJ ... e=youtu.be
Using an off the shelf $40 dual-Switch Bluetooth relay, I was able to create a remote ignition and starter app for my iPhone. Instead of having an ignition barrel and starter button, I can now switch the bike on and start it via my phone from 20ft away. It also keeps the bike's controls area super clean.
This particular relay also includes a temperature sensor that will be fitted to the top of the air-cooled engine next to the spark plugs. This will allow me to take very accurate engine temp readings and even log them at intervals over a ride to monitor engine temps. I can also have my phone alert me via SMS if the engine is overheating. Using a 4G data-enabled relay, I can switch the bike on (and off!) from anywhere in the world.
Hi all.
Some minor speed bumps on final assembly, if you could wade in with your wisdom - much appreciated!
1) Engine Sprocket
Is this the securing washer that should be bent around the nut? Doesn't look like it...?
2) Engine Sprocket Casing
This one is from a Z750A and does fit the engine - BUT it could the frame so no way to fit with the engine in place. Is it the wrong one? What case will fit without removing the engine - as I can;t believe you have to do that to remove / refit these???
This one appears to have a kick in that corner to clear the frame. Form a 1982 750-H
3) Chain fouls the top of the swingarm.
Not a total shock but how much is too much? I calculated the biggest front and rear sprockets I could fit to give me as much clearance as possible. Does the standard Nylon strip really do the job? Or this a result of bad design...?
1) Engine Sprocket
