GB's Modded Z900 now on a runaway budget!
eastlondon
Lad's, thank you all for your kind words.
Buzzard the head work was indeed a work of art, bloke that did it was a decent fella too.
Ignition is Dyna 2000, set up statically at 38 degrees BTC with ignition curve 1 selected & the rev limiter set at 9000 RPM. Once I get the thing on the road, I can tweak it as needed, but straight 'out of the box' it seems pretty good.
- coldsummer
I've managed to get some of the smaller jobs done during the last couple of Sundays. Nothing breath taking, but stuff that needs doing all the same.
Fitted & plumbed in speedo sensor. Seems to pick up quite happily on the edges of the disc, between the mountings.
Chopped off the Dyna 2000 pick up connector.
And fitted a waterproof version, as it sits under the rear of the motor.
Added a vent to my catch tank;
Fitted seat & temporary billboard No. plate;
Fitted handlebar grips, then drilled & fitted new badges to bodywork. Thought you might like a couple of pics with it's clothes on.
- wheelysteve
Is Vic There
Very nice, love the look of it and the exhaust has grown on me.
- Fred the Zed
