new member with Z900 project
#286 PostAuthor: Pigford » Thu Jul 04, 2013 7:38 pm
Get some decent Bell Mouths abd cover them with these beauties - specially made/designed....
http://ramair-filters.co.uk/ms-sock-fil ... lters.html
LondonZ1
#287 PostAuthor: LondonZ1 » Thu Jul 04, 2013 9:24 pm
Thanks for the suggestions guys. I will run the bike with the bellmouths for a while and see how it goes. I suspect the solution will be some custom alloy tubes and some form of foam or S&S filter hidden behind the side panels. The upside of having a minimal electrical system is that there is plenty of space to accommodate things I didn't think I would need; oil catch tanks, bigger filters....
Point also taken about the oil in the catch tank. I have seen some super-neat Japanese ones which come with sight glass and drain plug, so you can see when to empty the tank.
LondonZ1
#288 PostAuthor: LondonZ1 » Tue Jul 09, 2013 6:18 pm
The bike is back from Debben and ready to ride! I am looking forward to my commute tomorrow. The oil cooler is fitted and I think it looks OK. With hindsight (my most developed engineering tool) I could have chosen a bigger cooler but it's OK for now. There's a list of small things to do but nothing major so the main goal is to get some miles on the bike while the summer lasts. The exhaust sounds much quieter than I expected just revving the bike on its sidestand so the louder baffle will probably stay.
#289 PostAuthor: Rich » Tue Jul 09, 2013 7:08 pm
over cooling the oil is worse than running it too hot, only problem may be the air flow through it not the size
j.wilson
#290 PostAuthor: j.wilson » Wed Jul 10, 2013 4:29 pm
Get yourself a torque wrench
z650/1400 bonneville hybrid.
LondonZ1
#291 PostAuthor: LondonZ1 » Sun Aug 04, 2013 3:59 pm
After some research, I found these bellmouths in Japan. They have a simple fine mesh filter, are the right diameter to fit round the outside of carb inlets and are short enough to clear the side panels. Third time lucky!
I also fitted an inline fuel filter which you can see in the second pic. There was some cr*p on the float valve seat which caused the carbs to overflow and leak all over the garage floor. I thought the tank was clean inside but I guess you can never get all the dust out. The filter is transparent so I can monitor the cleanliness of the fuel.
I have also fitted a small rear plate, so all that's left is a redesigned tail undertray as the Mk1 design is not stiff enough. I'll probably leave that job for the winter though and just enjoy riding it in the meantime. I parked it in Wimbledon today and a guy came over and started saying how he used to have a Z650, what a lovely bike etc. It certainly isn't a bike for a recluse, it gets attention every time I take it out.
Jay1969
#292 PostAuthor: Jay1969 » Sun Aug 04, 2013 4:20 pm
Best get the 'MOTORCYCLE RACE USE ONLY' sticker off the carb
quick :sou
weaver
#293 PostAuthor: weaver » Mon Sep 16, 2013 2:14 pm
nice feature in Ps this month :)
LondonZ1
#294 PostAuthor: LondonZ1 » Mon Sep 16, 2013 2:53 pm
I haven't seen it yet so I hope it is a good write-up! It never would have happened without the inspiration and support from site members so thanks to all of you. The bike will be on the stand at Stafford as well.
Jay1969
#295 PostAuthor: Jay1969 » Mon Sep 16, 2013 3:33 pm
Congratulations, it's a very nice looking bike imo
#296 PostAuthor: Al » Mon Sep 16, 2013 5:28 pm
Very nice indeed.
Scroll down a little.
http://www.bikehps.com/isr/isr_brake_discs.html
#297 PostAuthor: Pigford » Mon Sep 16, 2013 6:41 pm
Soopa-Doopa :wink:
Darren Williams
PRACTICAL SPORTS BIKE Z900
#298 PostAuthor: Darren Williams » Wed Sep 18, 2013 2:52 pm
A great article ,thoroughly enjoyed reading it .
Well done Peter .
Jay1969
#299 PostAuthor: Jay1969 » Wed Sep 18, 2013 10:29 pm
Vendetta761
#300 PostAuthor: Vendetta761 » Sun Oct 20, 2013 6:38 pm
Yes very well done Peter!
A real pleasure to meet you and see the bike in the metal yesterday, truely a beauty to behold :shock: :lol:
I was mesmerised by yours and Padders Kipkawa as well as the Mk 2 (?) in the middle, my ghast was truly flabbered so I must have seemed a little dumbstruck what with those 3 and the wonderful original examples to feast my eyes on.
I will re read your thread again and then maybe ask a few questions about those calliper carriers...
Z1000 ST x 3 , Moto Guzzi G5 special ,V11 special.
