Engine painted using PJ1 satin paint. There is nothing inside the cases, I just bolted it together to save masking up the mating surfaces etc.
There was a LOT of cash spent on the engine.... new camchain and liska billet guide sprockets, tensioner, valve guides, 1mm oversize stainless valves, honed barrells, rings, new clutch plates, alloy camcover end cap things etc. The valve guides and valve cutting was done by Debben.
Should be a good motor now.
